fully controlled bridge
Hi:
I need some help. I gonna control the speed of DC motor, so I gonna use a single-phase fully controlled bridge rectifier. I have a NI USB-6008, with it a goona make the pulses to the scr's; so I need to know how can I synchronize this pulses with the frecuency of the source??, and how can I move this pulses to vary the speed?.
Thank you
(3,252 Views)
Is the "source" the mains 230 or 110 AC voltage ?
Why don't you apply the pulses after the bridge?
You need to tell us more , for your project.
(3,230 Views)
Of course you do that... typing without thinking... Smiley Tongue
I don't know  NI USB-6008 but i guess you can measure analog voltage. So you can find the zero cross point...
(3,223 Views)
Hi:
The source is 230 AC, I need to control the pulses for the SCR´s, with the
NI USB-6008 a can measure analog voltage so I can find the zero cross, and with it a can make the pulses, but I don´t know with wich function can I synchronise my pulse train with the source because I want to control this pulses to fired my scr´s in different parts of the sine wave of the source.
(3,205 Views)
If you can find the zero cross, you can synchronize your pulses, wherever you want as the frequency is stable, 50 Hz (or 60Hz).
You just measure time inside one half-period. Then another zero cross will occur, and you restart measuring time.
The only thing i am not sure, is that you probably need a real-time software to do that. If you rely on windows... you will have problems, for sure...
Message Edited by Pnt on 05-05-2008 08:17 AM
(3,187 Views)
