function: create an array through initial/step/number of elements
Does LabVIEW have the function which directly creates an array by giving intial value, step and number of elements?
thanks,
WT
(5,259 Views)
Accepted by topic author weitong
Look at the Ramp Pattern.vi in the Signal Processing palette.  Also, check the Ideas board.  I think someone has posted an idea there about adding a step option to the standard For loop.
Lynn
(5,257 Views)
You can use the Build Waveform function.
It is located in the Programming >> Waveform palette
Cory K
(5,256 Views)
Ramp pattern function works.
the waveform function works for graph function. But I need an array data for numerical operation.
Thanks.
(5,219 Views)
Hi weitong,
You can unbundle the waveform cluster and just extract the dbl array of data.
Paul M
National Instruments | Applications Engineer | www.ni.com/support
(5,186 Views)
