fuzzy logic example
Hi...I want to learn the basic designing procedure for Fuzzy logic system. I already go through the docs. I need basic fuzzy logic system. Could anyone help me with this....
(6,266 Views)
Hi azadplc,
just open the example VIs coming with PID/Fuzzy toolkit…
(6,260 Views)
Hope you well today. and thanks for your reply.  I am having very much eager to learn fuzzy logic in LabVIEW. I got one project paper which  is so neat and very easy to learn to fuzz logic. based on that paper I was develop fuzzy logic such as membership functions. input and output variables. Now, my need is, how do design the block diagram of VI, which is having the graph, closed loop controlling etc. Can you guide me with this?  For your look, I attached my block diagram screenshot.
(6,086 Views)
I am doing my research in Static Excitation Systems of Synchronous Generator converting PI base system in to Fuzzy based Excitation system, i have prepared rules for fuzzy controller but for further implementation of model kindly guide or provide any related link.
(5,933 Views)
Dear friends,
             I am trying to implement a fuzzy logic controller. I built MISO type FLC. One input is set point which i will numerically control and the other input should be acquired as analog voltage signal value of my sensor which i acquired through DAQ. The output of the fuzzy controller is to be connected with DAQ and the value should be generated as voltage signal through DAQ.
I have two queries??
1. how to feed the acquired analog voltage signal value of sensor as one input to the fuzzy controller
2. how to generate the output of fuzzy controller as a voltage signal through DAQ
     I hereby attached my .vi file. please go through it and give me an solution for this problem
thanks and regards
chandrasekar
09597748312
mds14m002@iiitdm.ac.in
(5,779 Views)
