fuzzy logic in biomedical data
Hi
Can I implement fuzzy logic in spectral biomedical data?
(2,471 Views)
That's a really tough question.
I could... But not knowing anything about you or what you want, how should we know if you can?
Let's keep it at "technically, you could".
(2,454 Views)
When I used Fuzzy Logic, it was using a 5x5 or a 7x7 look-up matrix.  Based upon the criteria you choose for determining where you fall in the matrix, why couldn't you use it?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,433 Views)
