fxlms
hi i have implement real time fxlms algorithm(active noise control).I have problem because the data processing time is a round 30 ms while the required is 0.125 ms for sampling frequancy =8 kHz. For data aquization also long time for sending and recieving the signal. can any one help to reduce time for processing and send and recieve the signal.( i read about circular buffer and cash memory) but i dont know how to deal with. I attached the code.
Message 1 of 9
(6,668 Views)
What OS are you using? If it is not a RT  OS, you will never reach 0.125 ms accuracy.
 For this kind of problems  FPGA is probably the best solution.
Michael.
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
Message 2 of 9
(6,660 Views)
i am using windows os.
Message 3 of 9
(6,651 Views)
As pointed out, if you want real-time, you can't use a Windows OS, or any OS that's meant for regular desktops. There is no way to guarantee a consistently timed process in these operating systems.
While sometimes code can be trimmed down you will never be able to prevent the operating system from going off and doing its own thing, and thereby completely messing up your control loop. In your code, for example:
  • You can remove the file writing part from the loop. This is likely eating up a good chunk of time.
  • Place the DAQmx Start Task for the write outside the loop, as you don't need to restart the task each time. This is also chewing up time.
  • Don't graph. Graphing takes up a lot of CPU time.
Other comments:
  • Your inner sequence frame is completely unnecessary. You can remove it, wiring up the stuff in a stream, thereby removing all local variables.
Message Edited by smercurio_fc on 06-17-2009 09:25 AM
Message 4 of 9
(6,641 Views)
can u send me the code
Message 5 of 9
(6,327 Views)
What code? To what are you referring?
Message 6 of 9
(6,323 Views)
the fxlms algorithm, thAT code..
Message 7 of 9
(6,314 Views)
im finding it very difficult to design that. actually im doing a project on anc in labview, hence i asked
Message 8 of 9
(6,313 Views)
I HOPET THAT YOU CAN HELP ME I HAVE THE SAME PROJECT ACTIVE NOISE CONTROL AND I DONT HAVE FXLMS 32 WHAT SHOULD I DO THANKS
Message 9 of 9
(6,098 Views)
