gRPC setup with labview
I found an example 'object simulation and interfernce' in the labview under examples.I want to setup grpc for this exmaple.How can i set up that?
I also found that some VI's associated with the example is missing.how to get the missing VI's?
Thank you in advance
(1,907 Views)
gRPC is still experimental at this point. The NI wrapper and scripting tools for it can be found here: https://github.com/ni/grpc-labview
But it's still not in a state that I would consider really workable. The final release is likely going to be still different, and either more complex or more locked down or both of them.
Rolf Kalbermatter  My Blog
(1,896 Views)
