gauge needle size (i.e. smaller?)
is there a way to make the needle on a gage smaller (i.e. if you wanted to
simulate a clock for time input and wanted the 'hour hand' smaller)?
(2,921 Views)
Use the control editor on the gauge and change the size of the needle
Kevin Kent
(2,921 Views)
when we try to reduce the size of needle then if there are more then two needlw them all needle to reducing.....i want to display like wall clock.....
With regards
RANJEET SINGH
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,455 Views)
