general histogram & negative bins
Hi. I'm building a system that should display a histogram with times from brain cell spikes. The measurement measures all spikes, but they have to be displayed relative to a time t0. So the histogram has to start at -t0 and run to (measurement time - t0).
I'm using the general histogram library function, but when I feed it with the necessary bins and data (both contain negative parts thus), it only displays the positive times. The axis starts from -t0 however.
You can check the VI I'm testing the histogram with.
What could be the reason for this strange behaviour?
(3,545 Views)
Here you go, fixed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,545 Views)
wow, that was pretty quick!
Unfortunately, I have Labview 6.01b3 while You are using 6.1... I guess there is no way I can open it?
(3,545 Views)
sorry, here it is in 6.0
Mike...
LabVIEW Champion
(3,545 Views)
