generate PWM signal for control DC motor using NI-USB 6009
Hi, I'm Okky
I have a final project to complete my study. I have problem how to generate PWM signal in LabView 2013. my plant is DC motor and I using NI-USB 6009. help me please
Best Regard
  Okky
(3,426 Views)
Okky,
You cannot create a good PWM signal with the USB-6009 because its outputs are software timed.  You might be able to get to about 100 Hz but even then there would be a significant amount of timing jitter.
You need a DAQ device with counters capable of PWM or possibly a device with hardware timed digital outputs.
Lynn
(3,380 Views)
You can generate a PWM signal with an Arduino Uno. And there are examples and an Arduino community here.
PaulG.
Retired
(3,371 Views)
so, what's a solution do you have for me ?
okky
(3,314 Views)
