generate a report on a tpc2106t
I'm usin a TPC2106T to drive a cRIO9073 during an experiment. I need to generate a report at the end of the experiment. How can I do?
Should I create the report on the TPC or on the cRIO?
Thank you for answering
(3,199 Views)
It's depends on what do you want to save in your report. Can you explain a little bit more about your report?
Yann C.
France
(3,168 Views)
I just have to save numeric values and some text.
If I can illustrate with a graph, it's better but not compulsory...
(3,152 Views)
(3,119 Views)
