generate a signal at 3kHz that has packets of sinusoidals themselves generated at 50kHz
Hmm, sounds tricky. If I understand you correctly, you are having a 50khz sinusoidal Signal with low amplitude and every 3 ms you want to overlay a strong 3khz sinusoidal for 1 ms?
Kind regards
Peter Weber
NI Germany
Message 11 of 15
(852 Views)
Actually, every 3ms I would like to generate a 50kHz sinus signal (sorry it's not 3kHz but 300Hz).
Thanks a lot.
Kind regards
Ninskaya
Message 12 of 15
(852 Views)
Hi Ninskaya,
I have written a small VI that should generate your desired Signal. Take a look at it. If you have any questions about the VI, please ask.
Peter Weber
NI Germany
Message 13 of 15
(686 Views)
Hi Peter,
Thanks a lot for writing the vi it will help me a lot!
Ninskaya
Message 14 of 15
(686 Views)
Thanks a lot for your vi, it works very well with the NI generator card.
Best,
Ninskaya
Message 15 of 15
(686 Views)
