generate a signal point by point from a formula
Hi everyone,
Im new to Labview and im learning to use it for my DSP course. I have been trying to find a way to generate a signal point by point from a formula but it seems i cant find it.
Does anybody have any idea about it?
Hung Chu
Message 1 of 8
(3,614 Views)
Try using function
\Program Files\National Instruments\LabVIEW 2010\vi.lib\measure\masignal.llb\Sine Waveform.vi
At output you will be getting a start time to, delta t and corresponding all y vaules. From this you can build the two array of t (time) and corresponding Y
Message 2 of 8
(3,611 Views)
Thanks Fuzzy,
But I mean from a specific formula to generate a point by point signal. In my case the formula is cos(wt)exp(-(t^2)/(T^2))
T and w can be set to be a constant.
Message 3 of 8
(3,608 Views)
All you need to do is to generate the array of t values. This can be done a variety of ways. You could use a loop, or you could use one the many signal generation functions, depending on what t is suppose to be. It may be that the simple Ramp Pattern will suffice to give you the required array of t values. Then just wire up the array through a bunch of primitives to get your formula.
For example:
Message 4 of 8
(3,596 Views)
Message 5 of 8
(3,585 Views)
Then simply auto-index a for-loop and put your FFT pt-by-pt inside the for-loop.
Message 6 of 8
(3,580 Views)
It showed me the result instantly. It's not like point by point.
My real onjectives are getting the signal point by point then FFT it every time a point is acquired so I think the graph should be continuing to move until i stop it.
Message 7 of 8
(3,565 Views)
Then put a delay in the loop so you can see it "point by point". It's doing it point by point, but it's so fast that it appears to you that it's not.
Message 8 of 8
(3,561 Views)
