generate a tone burst
Hei
I am trying to generate a tone burst signal. It is a 5 cycles sine wave (with a hanning window). See the attached document.
I am using a NI 5401 with the function generator NiFGEN.
I only need to generate this signal one time. I can't manage to get only one signal, the NiFGEN repeat this signal.
Somebody have any clues about this?
Olivier
(4,743 Views)
May be niFgen_Sweep_generator_example.vi located in the Labview library can help you... I do not have the board to test it but it seems that you can set the duration of your generation. Maybe you can use a sequence structure to generate one period and on the others periods generate a DC = 0V.
Hope it will help you,
Regards
David D.
(4,717 Views)
Thanks David
I tried with the example you show me. It is not raelly what I want because I don't want to sweep the frequency. But there is still the same problem: the niFgen generator is repeating the signal. I just want to send only one signal. If you have another clue, let me know.
Olivier
(4,703 Views)
I guess this is a long time ago for you now, but i wanted to know if you found finally the answer to your question? I have the same problem..
If you can remember..?
(3,836 Views)
Hi Alex,
Oliver has visited the forum the last time in April 2005. Do you think he is still active here?
Start a new thread instead of reviving this 11 year old conversation!
(3,825 Views)
