generate analog output to control the MTS407 controller
Hi
I have requirement where i need to generate an analog output signal (voltage) to control the MTS 407/458 controller
i'm using NI PCIe-6353 multifunction DAQ for this purpose which connects to MTS 407/458 via Connector blocks and
BNC cables..
So how do i program to generate the analog output so that user can apply different voltages to controller and control the
device..
Thanks in Advance
(2,968 Views)
What have you got so far?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,966 Views)
Sorry i didnt get what u r tring to say from ur first sentence
(2,957 Views)
Just finding out how well you are doing, what you have got programmed so far. If you can post your code then its easier for people to help you out and pass comment
(2,952 Views)
