generate arrays
Hallo
i have to generate a array so that i can give start frequeny like 20 KHZ stop frequency like 30 MHZ with a step of 10 KHZ. that means when i give my start frequency variable 20 KHZ. the final array i will get like this.
index 0) 20 KHz, index1) 30 KHZ 40 KHZ and so om upto 30 MHZ. i am thinking to use the while loop. but how can i generate such an array with these three varibles?
1)start variable 2)step varible and 3) stop variable.
thanks for your asisstance.
(3,239 Views)
You really should take a class in labview. See attached vi.
- tbob
Inventor of the WORM Global
(3,239 Views)
but the place i live, there is no labview class arranged.the only resource to leran is only internet
or some nice online book/tutorial.
any way i am trying to do that.thanks
regards
(3,239 Views)
