generate constant voltage under Specifying Conditions
Hope this will help you.
Munna
Message 11 of 17
(1,256 Views)
Ok, this can be simplified so much.
An Analog Output holds the last value that was written to it.  So you just need to set the voltage each loop iteration.  And you don't need the case structure either.  Use a Select function to choose your output voltage.
Initialize the AO task outside of the main loop and close it after the main loop.
Message 12 of 17
(1,235 Views)
Thank you Munna!!
Message 13 of 17
(1,209 Views)
Really Really thank you crossrulz !!!!
I'm trying to make I/P also as a virtual channel, but the daqmx event can't compare with constant directly...
Do you know me how to solve this problem?? I search from the internet but there is no solution...
Message 14 of 17
(1,207 Views)
And also, that is to control one relay. I try to put 2 of this program inside one VI but it can not work... I try to use two while loops or put them in one loop, both cannot work...
could you tell me how to put them together?
Thank you!!!!!
Message 15 of 17
(1,178 Views)
Message 16 of 17
(1,170 Views)
Cool
Message 17 of 17
(1,163 Views)
