generate continuous signal via audio output
Hi, I would like to use the create a square wave and send it to the output of the soundcard.
I managed to do it via the waveform generators, but the the waveform is not stable, nor continuous, as I am watching it via the oscilloscope. What I see is just packets of waves, buffering into the VI chart.
Shortly, the idea is to use this waveform ( 2kHz and 1V output) rather than using a signal generator, to control some piece of equiment here.
A.S.
(2,404 Views)
I think you might want to post your actual VI ... or a snippet of it.  Then we can provide more advice.
http://www.medicollector.com
(2,325 Views)
