generate pulse synchronized with function generator
Hey pram1,
Here it is in 2011 format.
Josh E
National Instruments UK & Ireland
Message 11 of 12
(470 Views)
Hello josh E ,
I will explain you my requirements here , I have attached my VI. The two simulate signals will generate square wave through analog output pins AO0 and AO1,  so AO0 signal goes to my laser and AO1 to a transistor to make it on and off(open and close) . I have sum external circuit from which I have to acquire data when a capacitor is charged , the capacitor will charge when there is a high pulse from the 1st simulate signal. I have to save the data and give a pulse to transistor to discharge the capacitor . This all has to be continuous.
Say if the pulse width to the laser is 200ms then every time I have to save the data at 150 ms .... And give the other pulse to the transistor to discharge . Any ideas to how to achieve this tasks .
Message 12 of 12
(469 Views)
