generate pulse
hello
I am looking the ways of generating a pulse of waveform so that i can simulate it  by mouse click.(Without any hardware)
I know that it is possible to start my waveform analysis once my input voltage(continuous acquisition) is over certain value, but i have tried it, but to no avail. pls help.
thanks.
regards
(2,947 Views)
heang,
So are you trying to figure out how you can begin the simulation of a waveform by clicking your mouse, or are trying to begin it when an input voltage reaches a threshold?  Where is this input voltage coming from if you are not using hardware?  If you want to produce a waveform once a mouse is clicked, you can use the event structure to acheive this.  If you are looking to produce the waveform once an input voltage reaches a certain threshold, I suggest checking out some of our DAQmx examples in the NI Example Finder (Help->Find Examples).  Specifically look at the Acq & Graph Voltage-Ext Clk-Analog Ref.vi example to see how to trigger off analog thresholds.  Hope this helps!
Brian T
(2,919 Views)
