generate report (just data out) from strip chart (DEADLINE LOOMING!!)
I have a VI that contains a dual strip chart ( Scalar data / Double precision floating point numbers) running in a while loop. One of the strips contains pressure information, the other contains deflection information. I need to know how to gather that data as it is recorded, save it to some kind of container during testing, and then output it in a format that I can see columns on Wordpad. Still waiting for MSOffice on my machine. I have tried several approaches, all of which ended in generating only the last 2 values measured. THis is a VI I just threw together yesterday, and it will be relaced by a (nearly completed) state machine next week. I just need something to hold me over until then... I have very little time left before my boss, who thinks LabVIEW is "Black Magic" comes back here to see my test run!!Smiley Sad
One should welcome adversity as an opportunity to excel.
(2,954 Views)
Store your data into an array during the while loop.
After the while loop, use the Write to Spreadsheet File to save it as a tab-delimited *.txt file, and open it in Notepad, Wordpad or whatever.
Or use the event structures to add a "Save Data" button.
Check out the examples, such as the Write to Text File.vi. Very helpful.
B-)
(2,951 Views)
Thanks LVGWB!!! You are a guru. I used the example to which you pointed. It worked great. I think I will still have my job. Being a newbie it is kind of overwhelming all of the "apparent" choices available. I appreciate you steering me to a good one.  ChrisSmiley Very Happy
(2,931 Views)
