generate sine wave triggered by impulse?
Dear all,
i am new to this labview software and signalling field. Ineed help on the following assignment task.
     - Generate a 50Hz sine wave triggered by impulse with decay rate of 6rad/s
I know it is a very simple program but i struggle to get the program done. Help would be much thankful.
Regards
Ken
(2,643 Views)
1. What is the hardware you use?
2. Please explain what is decay rate?
(2,621 Views)
Actually, no hardware is used, we just need to virtually generate a sample sine signal that is triggered from impulse from functions in Labview. It is for analyzation usage.
Decay rate is the signal will reduce by frequency of 6 rad/s or we put is as 6Hz for example.
(2,601 Views)
