generating HTML report with data types of cluster elements
I'm trying to generate an HTML report that includes the data type of cluster members, but in the report I create I can only see the data type of the cluster.
I use the Append VI List of Controls to Report.vi function.
Do you know if it's a bug or if I am not using the ...
(3,131 Views)
Hi Toniella,
If you add the type of control to your report, it add the Terminal Symbol on the report.
For a cluster it's the type of the Front Panel element.
I you wat to have all type of elements you have on the Front panel you must program it yourself or put the element on the Front Panel and Bundel it in your programm.
Have a great Day.
Matthieu
(3,118 Views)
