generating sound signal and record the timing using labview
can somebody help me in generating audio o/p from daq 6036 and record the same signal for reference.
(2,701 Views)
Kanth,
I think you will find there are lots of topics already on the forums talking about trying to do this.
Here are a couple of examples:
Forum: Continuous audio output with varying volume or frequency
Forum: How do I get audio output from a labview program
Probably the easiest way is to search the forums for what you are looking for:
Search Results on forums.ni.com for 'audio' and 'output'
Finally, here is an example program that may also help you:
NI-DAQmx: Acquiring Audio and Transferring It to a PC Sound Card
(2,688 Views)
Hi Otis,
Can you please send me the file in Labview6.1 version. bcoz i don't have labview 7.1
thanks,
kanth
(2,682 Views)
Unfortunately that file uses DAQmx, which is only compatible with LabVIEW 7.0 and up.
There were lots of other good posts related to this, they might have some older examples contained in them.
(2,677 Views)
