generating -/+ voltage with NI-USB 6009
Hello NI forum :). It's nice to join such a community 🙂
I hope you will be able to help me...
Is it possible to generate with 6009 card output signals outside 0 - +5V range?
I successfully generated a differential signal to run galvo by connecting my 6009 to a computer.  On AOO I generate a 0 - +5V signal and on AO1 constant 0V.
Is it possible to change this configuration/ add something to a program program and to generate differential -10 + 10V signal
(especially since the card accepts such input range?)
Thank you in advance for your help
Joanna
(3,208 Views)
Hi Liiung,
No.
The USB6009 works exactly as written in the SpecSheet
(3,168 Views)
<nodding her head with sadnes>
I had hoped some clever trick exist...
Thank you!
(3,160 Views)
Its successor, the USB-6002, has AO capabilities of ±10 V.
Bob Schor
(3,154 Views)
Thank you!
Assuming you are trying to create a sine wave, here's a trick to try...
Pass the 0-5v output through a capacitor and then an opamp to amplify it to +/-10V.
=== Engineer Ambiguously ===
(3,107 Views)
Well, if you're going to get "clever" like that, you can also do the following (you need a little understanding about Op Amps and how to use resistors and feedback to add (or subtract) two voltages and how to "multiply" (or amplify) by 4.
Assume you want a signal that goes from -10v to +10v, and you have a USB 6009 that only goes from 0 to 5v.  You want 0 v from the DAC to become -10v, and +5 from the DAC to become +10v.  To simplify the thinking, I'm also going to assume your "signal" goes from -10 to 10, so you'd "ideally" send it to a DAC that goes from -10v to 10v.
So what do you have to do to your signal?  Well, you can transform [-10, 10] into [0, 5} by dividing by 4 ([-2.5, 2.5]) and adding 2.5 ([0, 5]).  Send this to the DAC.  Now build a circuit that subtracts 2.5v (you can use AO1 to generate a +2.5v signal, and make your op amp do the subtraction) and amplify the result by 4.  Presto, the output goes from -10v to +10v.  It needs a few resistors (3?), an inexpensive op-amp (do people use 741's anymore?), and an appropriate power supply (±15v, probably).
Bob Schor
(3,088 Views)
