generation of 220 V
good afternoun every body . Please i want to generate a voltage 220rms from my compactrio .
is there any module to generate that , else not , is there any way to generate it ?
(2,570 Views)
There are companies which make high power amplifiers for line voltage and frequency applications. California Instruments is one name which comes to mind.
Lynn
(2,560 Views)
What are you trying to do with 220V?  Most likely, you will need a 220V source and a relay that you can control with one of your digital lines.
(2,557 Views)
