gesture recognition in Labview.which function can i use?
I am doing an project on gesture recognition in LabVIEW.Gestures are captured and transmitted to robot.The robot will mimic the gesture.Which kit can i use and what functions can be used to capture gesture
(4,867 Views)
Well that would depend on how you plan to capture the gesture in the first place?  Exoframe?  Camera? Kinect? Leap Motion Controller?  Other?
If you were planning to use a camera then you may want to look at the NI Vision tools.
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(4,851 Views)
ya, thanks..im going to capture entire body gestures.. will idea of using a camera work??
(4,831 Views)
Well it's a bit out of my experience so I don't know for sure, but my first thought is that an image from a single camera has limited depth information.  That might limit your ability to recognize different motions.
The kinect was designed for full body gesture capture.  It would probably work best.
Wire Warrior
(4,818 Views)
And if you are looking at the kinect, do a search on these forums, there was a fair amount of discussion about interfacing with them a while ago.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,809 Views)
thanks bro..
(4,808 Views)
can u tell me which kind of sensor would help??
(4,805 Views)
