get Labview exe folder
Hi!
How can I get the Installed LabVIEW.exe or labview palette path from exe?
(exe is created in LabVIEW)
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 1 of 9
(11,903 Views)
There is a Application Directory VI under the File Constants pallette that will give you the path of the running vi(.exe).
Returns the path to the directory containing the application.
If you call this VI from a stand-alone application or shared library, this VI returns the path to the folder containing the stand-alone application or shared library.
If you call this VI from the development environment and the VI is loaded in a LabVIEW project file (.lvproj), this VI returns the path to the folder containing the project file. If the project is not saved, this VI returns <Not a Path>.
If the top-level VI is not loaded in a project, the VI returns the path to the directory containing the top level VI. If the VI is not saved to disk, this VI returns <Not a Path>.
Message 2 of 9
(11,900 Views)
As noted, the Application Directory function will return to you the application's directory, i.e., your executable's directory. Why are you trying to get the location of the labview.exe file from your executable? There's no guarantee that the LabVIEW development environment will even be installed on a target computer, since the built executable uses the LabVIEW Run-Time engine, not the LabVIEW development environment.
Message 3 of 9
(11,879 Views)
I would need the folder/directory of Labview.exe to copy a folder that provides a custom functionality to the installed Labview version.
So is there actually a simple way of getting it instead of scanning through the local volumes and folders until you find it?
Message 4 of 9
(11,540 Views)
I would recommend getting VI Package Manager for that.  With it, you can build up a package and install it on each version of LabVIEW you have installed.
Message 5 of 9
(11,530 Views)
Thanks for your reply. In the meantime I have found also another possibilty to get the path by using the "VI Library" Function that returns the path to the 'vi.lib' file that usually located in the same folder as 'Labview.exe'.
Message 6 of 9
(11,507 Views)
An even easier way, if you are trying to run this in Development mode (as opposed to "as an executable", is to simply drop an Invoke node and ask for the Directory Path.
On my machine, Application:Name is "LabVIEW.exe", and Application:Directory Path is C:\Program Files (x86)\National Instruments\LabVIEW 2012.
BS
Message 7 of 9
(11,476 Views)
@D60 wrote:
Hi!
oz
Message 8 of 9
(10,329 Views)
@D60 wrote:
Hi!
OZ
Message 9 of 9
(10,328 Views)
