get VI connector controls and indicators
Hi all,
i'm trying get list of VI controls and indicators that are connectors.
I need it because i write VI that get path of some VI from user and later user must to enter values of input controls and view results (indicators)
(2,877 Views)
Correct me if I'm wrong (no LV here), but doesn't the connector pane property (VI class) return an array of references to the controls used in it?
___________________
Try to take over the world!
(2,858 Views)
The problem that the connector pane property is only for writing. (LV 6.0.2). May be in more later versions it can be readed also, but i don't know. Additionaly this property is refnum of VI (not array of control refnums).
There is another property "Get VI Controls", but it get all controls of VI and i need only controls that included to connector pane.
(2,847 Views)
Actually, we're both right.
The conpane property is write only by default, but using scripting you can read it and get an array of references to the controls. If you want it, either post your email and I'll send it to you or go to the LAVA forums and ask for it there.
___________________
(2,847 Views)
Thanks you tst.
Please send it to my mail:
nadav.ch@civcom.com
(2,837 Views)
