get X axes values by indexing
Hi
I would like to know why in the folowing example I have my X axe graph's values are the  loop  iteration index(1st column)  instead of  the values of the 2nd column(time)
I want my graph with Y value according to time(2nd column values)
I thougt I was supposed to do it like that but it's not working as I want
could somebody explain me why?
I join my VI and the txt file
thank you
Olivier
(2,596 Views)
Hello Olivier,
you are using waveform data in your VI. Waveform data requires that you have sampled your data at a constant rate and wire this information to dt.  Your x.txt contains distinct time values when acquisitions were done and the dt is not a constant. So your data is a good candidate for an XY Graph. This one supports an array of (x,y) coordinates. You can also wire more than one graph to an XY Graph.
Best regards, Guenter
(2,585 Views)
Hello gueter
Thanks very much for your speedy reply ---your  answer is the fastest I have ever received. perhaps because I usually use french community forum.and thank you so much your answer is also exactly what I needed to know.
Olivier
(2,582 Views)
