get actual clock rate error
I'm using ADAC 5500 DAQ card with labview. I had an error called 'get actual clock rate'.What's the meaning of this error. How can i get actual clock rate,what shoul i do?Thanks for your response.
(2,617 Views)
Hello �
I visited IOtech�s website and found out that in the ADAC/5500 Series specifications data sheet it is mentioned that LabVIEW is supported with this piece of hardware. They mention: �complete drivers with example programs for rapid application specific development�.
My suggestion is to contact IOtech. They are the ones who wrote the driver to interface their hardware with LabVIEW and should know what the error means. In this case, our ability to help you is limited since we did not write the driver. However, they should be able to provide you with more information about the error and how to fix it.
ADAC/5500 Series
IOtech support<
/a>
Hope this helps!
S Vences
(2,617 Views)
Thanks for your reply. I've contacted IOtech and waiting for their response.
(2,617 Views)
