get all children of a parent in tree
I have a database set of files... each file has test results where I have read them into a tree control and sorted them by test number.
What I need to know is when I select a specific file, how can I get all the tests that are in that file into an array?
In other words, when I select a parent object in a tree, how do I get a list in an array of all the children to the selected parent?  Is there a property or something to "get all children"?
(8,458 Views)
Hi id,
see the attached example.
Hope it helps.
Mike
(8,439 Views)
Thanks Mike,  this helps me a lot.  I guess I first have to determine the first child by using the getchild method and then iterate using getnext method until there are no more...
Smiley Happy
(8,424 Views)
Norman Kirchners Tree API, has several (new) methods for Trees:
Add Item
Modify Item
Remove Item
Get All Items
Get Top Level Items
Get Items Parent
Get Selected Item
Get Siblings
Get Children
Get Item Properties
Check Tag Valid
Convert Tag to Text
Find Tag from Text
Outdent at Item
Indent At Item
Expand
Collapse
Empty Tree
Ton
My LabVIEW Ideas
(8,404 Views)
MikeS81,
Good example.  Also good choice of cars 🙂
Jared Boothe
Staff Hardware Engineer
(8,385 Views)
