get data from C/C++ with activeX-LabVIEW
We try to get data from C/C++ with activeX-LabVIEW.  We are successful to get numeric or string data type but we have trouble to get array or cluster data type.  Would you please give us some example?
Kim
(2,681 Views)
The question is not completely clear. Do you have an ActiveX DLL that you're trying to call from LabVIEW, or are you trying to control LabVIEW from C/C++ using ActiveX?
If it's the latter you may want to take a look at the example posted here.  A search may yield additional examples.
(2,670 Views)
