get error 89140 running example' PID control -single ch.vi '
(2,600 Views)
Hi Fran,
From what I understand, you are receiving error 89140 when running the example "PID control - Single Channel". The following KnowledgeBase might be helpful in solving your problem:
Error -89140 When Routing a Signal for a DAQmx Device In a PXI Real-Time System
Let me know if this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,586 Views)
