get html
Hi all,
I am trying to write a little program to navigate to a transport website, enter a tracking number, submit it, page scrape the html, pass the string it to get the status of the order.
The code I have attached is my attempt at navigating, entering tracking number and submitting.
For some reason the submit function does not seem to actually submit the data and return the status page.
After I get this page to return the tracking information, I think I have other bits of code I can use to get the data I need from it.  I will then run it multiple times to get a list of items in an excel sheet.
Any help on this code would be great.
Thanks in advance
(3,184 Views)
Hi Sniepsy,
Please look at the source code of the page you are trying to submit the tracking information to, and note that the submit functions on this page is implimented in javascript.  So when you call the Submit function, nothing happens.
onclick="checkAndSubmit()
Instead, use the IHTMLElement method "Click" on the "track" button, and that should work.
Yi Y.
http://www.ni.com/support
(3,151 Views)
duplicate thread
The question is: how to ""Click" on the "track" button"! Smiley Wink
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,134 Views)
