get image data in vc++
hi  all,
i'd like to use vc++ to process image data (read/modify pixel values, display the image, etc.) through imaq library.
sample code:
// get the frame
imgGrab (Sid, &ImaqBuffer, TRUE);
// display it using imgPlot
imgPlot ((GUIHNDL)ImaqSmplHwnd, ImaqBuffer, 0, 0, AcqWinWidth, AcqWinHeight,
CanvasLeft, CanvasTop, plotFlag);
imaqBuffer ist the buffer for storing image data, which was declared as follows:
static
 char *ImaqBuffer=NULL; // acquisiton buffer
How can i get the image data from "ImaqBuffer"? (how to get the buffer size?)
thx a lot!
scott
(2,590 Views)
Hi Scott, wit installing NI-IMAQ you will get examples.  You can find them in C:\Programme\National Instruments\NI-IMAQ\Sample\MSVC\Grab I think they will answer your question.
Thanks, Rebecca
NI, Germany Applications Engineer
Rebecca Fox
(2,577 Views)
