get image of control in subvi
I want to get image of control in subvi whose front panel is not visible. Now I solved it with "blinking solution" with the aid of "Show panel when called" and "Close afterwards if originally closed". I still hope that there is another better solution. I'm woriking with LV v 8.6.
I have read this in help : If you do not want to display the front panel but want the image to reflect value changes, create a Property Node from any front panel terminal on the block diagram of the VI for which you want to create a front panel control image.
But I don't know what Property Node I have to use.
Thx for your help.
(2,877 Views)
Something like this?
Jean-Marc
(2,871 Views)
Yes, this is exactly the same type of calling subvi, but my subvi was more complicated. I reduced it and now is everything working perfect. I don't know what caused behavior described before, but it is gone .... 😉 thank you
(2,847 Views)
