get install location
My situtaion is that I have a labview project with an installer.
I have no executable(s) only vi's.
The vi's I build will be used in teststand.
In teststand I have created action templates, the templates location of the files must be adjusted so that if you install the files to "c:\program files\" the path must be "c:\program files\test.vi", this can ofcourse be any directory.
Question remains how can I do this?
(3,364 Views)
Hello Inspector,
Have you considered deploying the VIs from TestStands' Deployment Utility?
Eirikur Runarsson
(3,266 Views)
Hi Eirikur,
Thank you for your reply.
I'm not familiar with teststands deployment utility.
I'm now using a batch file.
I don't know exactly where to copy the drivers in de instr.lib directory if you have more then one labview dev. installed or more runtime engines.
The VI's I make are not compiled to an executable but called directly by teststand 2014.
gr,
Bart
(3,250 Views)
Hi Bart,
Please read trough these:
Deploying LabVIEW Code Modules with NI TestStand
TestStand Deployment Utility
Eirikur Runarsson
(3,192 Views)
