get main vi control or indicator from subvi using cluster reference
I have a MainVI control references, bundled, going into a subvi. I am seeking an excellent way to read the value of the control or indicator. I seen post for setting the control using "vi methods". Not sure how to work out the "control name". I'm thinking this is possible from the control reference and a property node.
Any ideas?
Rich J
Message 1 of 9
(3,884 Views)
Let me add, I'm using 17+ controls and more to add later. I am trying to avoid using 17+ property nodes for all controls on front panel. I would like to put 1 property node in a For or Case stucture and process all the controls from this For or Case structure. How could I avoid all this wiring of property nodes?
Message 2 of 9
(3,869 Views)
Hi Richjoh
Could you post some code. I don't have a clue what you want.
Ton
My LabVIEW Ideas
Message 3 of 9
(3,855 Views)
I am trying to find another way to read the value of FP control w/o using variants. (I'm told variants use up more memory than necessary). I attached one my attempts below. If there is no other way to work around a variants how do I properly convert a variant to a value w/o loss of data?
I know how to use references to a FP control and property nodes to the control's value (no variants here). But this get messy on the block diagram if there are many FP controls.
Message 4 of 9
(3,843 Views)
richjoh,
You could use the invoke node "Ctrl Val.Get All [Flat]". This returns an array of clusters of flattened data. This might be more of what you're looking for. Post to let us know.
Chris C
Message 5 of 9
(3,833 Views)
Hi Chris C.
I'm not sure how to set this up. could you give me a clue or post some code. Much appreciated.
Are you saying I can use this to get or set a control on a vi FP? I'm trying to avoid using variants.
Message 6 of 9
(3,829 Views)
Hi Rich,
You will get better answer from us if you post a simple example of what you are attempting.
Lacking that...
The "Variant" can be avoided if the refernce wired to the "property>>>Value" node is of the specific data type used by that control.
The "to more specific class" node can be used to cast a generic ref to the proper type. Just wire a reference of the proper type to the top terminal to cast the reference.
Generally:
You will get generic refernce when ever you get the "controls" from a cluster because this is an a array and they all have to be of the same data type.
You'll also get generic refences if you build an array of different refence types.
A possible useful trick is to use multiple "To more specific class" nodes (in a case ?) and check the error cluster it returns. If the "to more..." does NOT return an error, the "thing" was of the class you tried.
Like I said to start, You'll get better answers if you post example code.
Ben
Message 7 of 9
(3,815 Views)
hey richjoh,
Check out the example called Saving and Loading Front Panel Control Configurations. This demonstrates (using the property nodes I mentioned) how to caputre all of the values of your front panel controls and indicators and write them to a file. You can then read that file and populate the controls \ indicators with the saved values. I think this should help out a little more.
chris C
Message 8 of 9
(3,807 Views)
Chris C.
Thanks, this is an excellent example of what I am trying to do. I now know when I drop an Invoke method on the block diagram, I should (right click) select the class (in my case "control") then I can set Control methods.
Prior to this I kept dropping an invoke node and didn't know how to set the invoke method for a control besides wiring a Control reference straight to the invoke method. Now I see, Invoke method class is "VI Server>App" when its dropped on the block diagram.
Smiley HappyThanks again
richjoh
Message 9 of 9
(3,801 Views)
