get mapped drive information in LV
Is there a way to output the full server name for a mapped network drive?
i.e. go from the mapped drive letter R:\ and have it output the full path \\Mapped_Drive1
Thank you in advance...
maat
LV2019
(3,931 Views)
Accepted by topic author maat
There is no direct way of doing that. You can, however, do it, using a Windows API call to the WNetGetConnection function. See attached example. The buffer for the UNC path was arbitrarily set to be 100 characters.
(3,923 Views)
Exactly what I was looking for, thanks again!
maat
LV2019
(3,920 Views)
I attached the final VI in case it helps anyone.
maat
LV2019
(3,913 Views)
Works great, thank you!
(3,841 Views)
