get max value of xy graph
Hi
I'm generating an xy graph in multiple calls.
after the last call i want to know the max y-value. how can i get that?
thx simon
Using Labview 7.1
(4,037 Views)
Hi Simon
Depends on how you have created your XY chart. If you have an array of clusters see the attached diagram, if you have a cluster of arrays then just extract the Y array from the cluster and find the Max Y in a similar way to the diagram.
Hope this helps
Ian
(4,028 Views)
you have different way to build an XY graph (multi/single plot, etc) depending on this, the way to proceed will be slightly different.
but to access the whole data in the graph at the end, you can use a local variable and unbundle plot by plot to get the array that correspond to each Y plot, then use the "Array Max & Min" function in the array palette.
If you need further help, post your VI 😉
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,026 Views)
