get minima from curve fit array
I have data in a 2Xn array with voltage and position readings which I have put into a curve fit. Voltage follows a parabola and I wish to get the position at the min voltage. The position array is independent and voltage array dependent and fed into 'general polynomial fit.vi' with a 2nd order curve. Now the return array does happily follow a nice curve representing the voltage, but is 1-D and does not return 'x' values to represent my position. If I had this data I would simply get the min and then position and Im set. When I feed my data into the array I have a curve fit array which seems to ignore the actual positions I put in. These are of utmost importance. Any curve fitting experts? Your help is appreciated. Matt
(2,868 Views)
Hi Matt P,
the " general polynomial fit.vi" will also return an array of the coeficents. These are returned in assending order starting with the constant term.
The array you are plotting is the polynomial evaluated using the returned coeficients at the point you supplied. Or...
V = c + bx + ax^2
where
V= Voltage
X= Position
The extremes of V will occur where dV/dx=0.
Differetiating the above expression we get;
dV/dx = b + 2ax
Setting dV/dx equal to 0 and solving for x;
0 = b + 2ax
-b = 2ax
x = -(b/2a)
So the exteme occurs at -b/2a.
Use
the element at index "2" for a,
and
the element at index "1" for b
and you have your minimum.
Ben
(2,868 Views)
