get mouse's data from myrio
HI
I'm  trying to get mouse coordinates from myRIO
but there exist only joystick VI Using this VI i can get mouse's button data but not coordinates data
can i modify joystick VI to get mouse data?
i also tried to communication with ps2 mouse has om02 chip
spi, ic2, uart and serial...
what should i choose the protocol?I  don't know communication well
what can i do to solve this problem?
thkanks for reading ^^
(3,382 Views)
Hi abceeee,
did you google for "ps2 mouse om02 IC"? The first hit is a datasheet for that chip, with descriptions of pins and protocol…
(3,353 Views)
Firstly, there is a dedicated forum for the myRIO - here.
Secondly, the myRIO runs a variant of linux so it may be that the support for a USB mouse is already there, you just need to find a way to get that data into LabVIEW - that's pretty much where the extent of my knowledge for this kind of thing runs out - there might be a device node you can read from using the file I/O functions and/or a console command (using system exec) you can run which gives you the mouse position. There are lots of software packages you can install to your myRIO...so there might be a compiled package already available.
I just found this example for reading from a USB Keyboard: https://decibel.ni.com/content/docs/DOC-39006
(blog)
(3,345 Views)
thanks for your kindness
I saw this datasheet already...TT
I can't catch what  i need...
Thanks again
(3,330 Views)
