get report page numbers
I am generating a test data record in Word with generating report toolkit. On every page I put in a footer text to the left with the date and time.
(in Labview with "set report footer text").
I also put in the Word template for the report, page numbers on the bottom RH side. When I run my vi I get the the footer text on the LH side,
but I loose the page numbers on the RH side. How do I solve this ?
(2,708 Views)
Hi BartvStC,
how do you try it? Can you upload your vi? If i create a "template" and connect the path of it to "New Report" i can write my text to it and the footer is correct.
Mike
(2,684 Views)
Okay, here is my vi. I use Labview version 8.2.1.
(2,682 Views)
Hi BartvStC,
i´m not sure what i should see in your vi, it don´t show what you make. Smiley Happy
Attached you will find the vi with which i made it, the template doc and the result doc.
Mike
(2,679 Views)
