get the last index of a string array
how to get the last index of a string array? the array size is always changes in certain situations
Message 1 of 16
(789 Views)
Hi sinclair,
You want to know the ArraySize? Then why don't you determine the ArraySize?
(When you want to get the value of the last array element (of a 1D array) then use DeleteFromArray…)
Message 2 of 16
(783 Views)
Ok gerd thankyou, the problem has been resolved
Message 3 of 16
(748 Views)
Hi sinclair,
In which way did you solve the problem?
(You know in a public forum it's important to provide solutions to questions with some explanations. Others may benefit from your detailed answer - the same as you learned from asking…)
Message 4 of 16
(742 Views)
For any array (not just an array of strings, what I assume you mean by "string array"), the index of the last element (I assume that's what you mean by "last index") is the array size minus one.
Message 5 of 16
(700 Views)
@GerdW wrote:
Hi sinclair,
Note that when you don't wire the "index" input of "Delete from Array", it deletes the last element.
Message 6 of 16
(671 Views)
Obviously I am not versed in reading between the lines, but from the question, I assume ....
  • They are just interested in the index, not the value of the element (Delete from array does not give that information)
  • They want to keep the array intact. (Delete from array does not do that, so we need to branch the array first and continue with the intact version).
Of course the deeper question is why the array size is constantly changing and why they are interested in the "last index" (sic). Maybe they just want to determine the location where to append new data (e.g. using the misguided "insert into array"), something that is not necessary with the right primitive (i.e. "built array", possibly in concatenate mode). 😄
Sometimes the code can be rewritten to keep the array size constant and be less taxing on the memory manager, but for that we would need more detail about the requirements....
Message 7 of 16
(652 Views)
I never mentioned to use the array output of DeleteFromArray, I just suggested to use the "deleted element" output of that node.
For the broader audience: DeleteFromArray can be used as a shortcut to "index the last element of an 1D array".
(I know that you know this, Christian. 🙂 )
Message 8 of 16
(632 Views)
I sure hope that "delete from array" can eliminate the creation of the shortened array output if nothing is connected to it. I have never done any benchmarking.
(Back in the nineties, "delete from array" did not even exist and I still rarely use it) 😄
Message 9 of 16
(624 Views)
You are right, and I made myself a polymorphic VI with that function. I called it "Pop Array Element" since I had some Perl- experience and there this task was named this way 😁
It also took me some time to get used to the "Delete Array Element"...
Was Hänschen nicht lernt, lernt Hans nimmermehr! 😉
Greets, Dave
Message 10 of 16
(604 Views)
