get user name
Hi I need Labview to programatically create a file in the C:\Documents and Settings\"Username"\Application Data\ folder but i do not not how to find the user name.  I tried the "Get permissions' function but that returned nothing for the owner and group
My only other choice would be to use the temporary directory filepath and work backwords but that is not very clean
thanks
(5,356 Views)
Hey,
Please open and run attached VI, this should help.
Christian
(5,346 Views)
Alternatively:
(5,339 Views)
Thanks, I am going to give these a try
(5,335 Views)
Can't you just drop a property node (Application Control | Property Node) and select "Application | User Name"?
(5,320 Views)
