get value form subvi
Hi all
I have two sub vi , I want to get string value fron one subvi to another
How can I do that
(3,609 Views)
The fundamental way is to create an output terminal on one of the subvi's and an input terminal on the other subvi and then wire the two together.
Reference LabVIEW Help under connector panes and assigning terminals.
(3,601 Views)
Hi
I try to do that , but an error "A wire can be connected to only one data source, such as a control's terminal or a function output. This wire is connected to more than one source. If one source is a control, you may wish to change it to an indicator.  Otherwise, you must disconnect all but one of the sources."
i look at the help it said  place inputs on the left and outputs on the right to prevent complicated or confusing wiring patterns
also i try that but it did work
(3,589 Views)
Hi
(3,589 Views)
Controls are Inputs
Indicators are Outputs.
Wire ONLY one control or Indicator to one terminal. (Labview does not permit you to wire more than one.. how did you do it !)
(3,579 Views)
thanks
i have solve it ,, i don't explain my self well
any way thanks
(3,575 Views)
