getchar() in Labview 5.1
I am new to Labview and am looking for a function that will return a
character every a key is pressed. Is there such an animal or how does
one go about doing it in LV. I want to compare every keypress and do
some thing based on it.
Sent via Deja.com
http://www.deja.com/
(3,377 Views)
Go to the NI Developer Zone and you'll find a keyboard utility at Resource
Library>LabVIEW>User Interface>UI Programming.
alwal@my-deja.com wrote:
>I am new to Labview and am looking for a function that will return a>character
every a key is pressed. Is there such an animal or how does>one go about
doing it in LV. I want to compare every keypress and do>some thing based
on it.>>Thanks>>>Sent via Deja.com>http://www.deja.com/
(3,377 Views)
somewhere there is a keyboard.llb library of functions that do what you are
looking to do. I do not know the keeper of the code. It might be NI.
Stu
wrote in message news:95ppad$rhd$1@nnrp1.deja.com...
> Thanks
> Sent via Deja.com
(3,377 Views)
You might see if this works for you...
In the speed menu (right-click menu) of the String control there is an
option called "Update Value while Typing." (LabView 6i)
I used it for a real-time text parser.
Good luck,
Bob
> Thanks
> Sent via Deja.com
(3,377 Views)
There are some keyboard VIs on the ftp site. I think they are in the LV31
directory.
Greg McKaskle
(3,377 Views)
