getting a string from a DLL thru a pointer
I have a DLL that I need to call in order to translate a numeric identifier into a string.
The DLL function has the following prototype:
extern "C" __declspec(ddlexport) wchar_t* GetNumericString(int nId);
The difficult thing is that the DLL returns a wchar string pointer.
How can I get to the actual string value?
Also, I assume I have to free the string memory since I do not know how the DLL can otherwise know that I'm done using the string?
Note: I already created a LV function that can translate a U16 array into a string LabVIEW string.
Any idea on how I can get to the actual string value of this DLL in LabVIEW?
Thanks for the help!
(3,653 Views)
I worked around the problem by creating a DLL that handles the string pointer and returns me the string information to LabVIEW.
I'm still interested if anybody can give a hint how I can do this directly in LabVIEW. (without the need of my extra DLL)
(3,635 Views)
Hi Noxus,
Since Labview doesn't work with pointers, you are not able to get the string out of a pointer without another DLL. So what you are doing is the best option.
Bas van Dijke
AE, The Netherlands
(3,587 Views)
