getting images continuously
Hello, I'm adquiring data continuously, and getting images of the signal when an event occurs (and this even occurs often). I'm saving the images in a png file and after I introduce images in a report, but it uses a lot of cpu and after a time my program stop. What can I do, can I introduce images whitout saving it ?
Please, help! I don't know what to do.
Thanks.
Luz
Message 1 of 18
(6,099 Views)
Hello Luz,
When using images functions, it is quite easy to use alot more memory and CPU than you need to perform simple image processing. You have to allocate the memory in a sensible way with respect to your application.
Do you display this images on the front panel during execution or do you just save them to a folder ?
Could you post your code (or screenshots of you diagrams) so that we see how you are doing this ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 18
(6,091 Views)
Is it the same code as the one you posted priviously here or have you made changes Smiley Surprised ?
Anyway, if you post the VI it will be easier to help...
Other question, do you have the Vision library in your palette functions (see image below) ?
Message Edité par TiTou le 04-27-2006 10:53 AM
Epictetus
Antoine Chalons
Message 3 of 18
(6,089 Views)
Yes Titou, is the same code I posted before, and as you see I show in the front pannel the control and after I save it like an image. And I haven't Visio palete. What can I do?
Thanks a lot.
Luz
Message 4 of 18
(6,083 Views)
Well, please post the VI and I'll try to improve it as much as I can.. 😉
Epictetus
Antoine Chalons
Message 5 of 18
(6,077 Views)
Hello TiTou, I send you my code, thanks, can you help me?
Luz
Message 6 of 18
(6,076 Views)
Hola Luz,
He mirado el VI pero no tengo bien claro lo que quieres hacer... Smiley Indifferent
Primero me parece has borrado una parte de VI porque queda mucho espacio blanco y seria buena idea intentar disminuir el tamaño del diagrama ; se suele decir que el diagrama no debe ser mas grande que la pantalla ;).
Luego, creo que imagenes en JPG o PNG serian mas appropriadas para ahorar espacio del disco duro.
Ahora, te describo lo que entiendo, me diras si me equivoque, vale ?
 - quieres guardar a disco imagenes de cada fallo del proceso y añadirlas en un documento HTML, es necesario guardar todas las imagenes a disco ?
 - una imagen debe mostar 2000 puntos 1000 del falloy 1000 despues, eso es ?
Si es eso, creo que hay manera mas simple para hacer eso.
Epictetus
Antoine Chalons
Message 7 of 18
(6,063 Views)
Hola, que bien que hables español, de dónde eres?. Sí que he borrado parte del programa, he dejado lo justo para que entendieras mi problema. Quiero hacer eso, guardar 2000 puntos de señal, 1000 anterior y 1000 posterior del punto en que detecto el fallo. Tienes razón con lo de usar imágenes png, que me ocupan menos. Lo que quiero es guardar las imagenes del control en un .html, las creo como paso intermedio. Dices que crees que hay una forma más sencilla de hacerlo...¿cómo?. Muchas gracias, la verdad es que no sé como resolverlo.
Gracias.
Luz
Message 8 of 18
(6,056 Views)
Como le puedes ver en mi perfil soy Frances y trabajo en Suiza, el español lo hablo mas o menos (fortunamente no se puede oir mi accento cuando escribe :D) porque estudié 6 meses en la Universidad Carlos III en Madrid al fin de mi carrera universitaria.
Al curro no tengo oportunidades de utilizar mi español asi que se esta yendo Smiley Sad... Por eso, siempre y cuando hay ocasiones... 😉
Y tu de dónde eres ?
El tema de las imágenes lo voy mirar esta noche, la verdad es que utilizo poco - sino nunca - los "pict controls", por otro lado estoy acostumbrado a "jugar" con  los graficos y los "arrays".
@sta mañana 😉
Epictetus
Antoine Chalons
Message 9 of 18
(6,052 Views)
Yo soy de Valencia, española. Pues si esta noche lo miras me haces un gran favor, porque yo he estado probando cosas pero sin demasiados resultados. Muchas gracias entonces y hasta mañana, voy a seguir probando cosas a ver si consigo algo.
Gracias,
Luz
Message 10 of 18
(6,052 Views)
