getting matlab example code for daq cards
I tried to find examples and search the forum, but couldn't find it.  Anyone know where I can get a generic example of the code at?
(2,650 Views)
What NI device are you working with?  If it is a newer card, it will be supported with NI-DAQmx, and this post should help you out.
If you are using a device that is only supported with Traditional NI-DAQ, then this post should help.
Once you have the correct libraries loaded, you should be able to follow the same functions used in the text based example programs that ship with the NI-DAQmx or Traditional NI-DAQ driver you have installed.   These examples can be installed and located as per this KB.
Let us know if you have more questions, and best of luck on the application.
Have a great day!
Travis W
Message Edited by Travis W on 10-11-2006 09:58 PM
(2,639 Views)
